Re: 300 starting Problem
Posted by Siefring Red Farmer on December 17, 2008 at 09:39:57 from (12.37.116.130):
In Reply to: Re: 300 starting Problem posted by J in PA on December 16, 2008 at 11:26:02:
I checked this out last night. There was only one big one, where the power enters the motor fromt the solonoid switch. All the solder appeared to be in order. All connections were made properly, tested with a screw driver and pryed on them a bit. All other connections seemed to be made internal as well. I used an Ohm meter and only was getting about 450 amps. The battery is rated for 1000CC Amps. The battery is making voltage, but I am beginning to wonder is it is capable of outputing the Amperage needed. I will get a new battery and test this theory soon.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
