Explain, please!
Posted by Bob on December 17, 2008 at 10:24:03 from (69.178.228.68):
In Reply to: Re: Govenor question posted by Red Dave on December 17, 2008 at 05:06:18:
"There is a spring in the governor which, if broken, will cause the symptoms you describe."
If the governor spring is broken, it will NOT throttle up at all, not even at startup.
How would you explain the broken spring only giving truble after 5 minutes?????
