Re: Low Usage Tractors And Oil Change Frequency
Posted by Bob M on December 17, 2008 at 10:31:04 from (151.190.254.108):
In Reply to: Low Usage Tractors And Oil Change Frequency posted by Red Mist on December 17, 2008 at 10:07:22:
I too put only 40 - 50 hours a year on each of my 3 old tractors. And for the last 10 years or so I have been changing the oil/filter only every 2nd year.
My tractors stay under cover in an unheated shed when not in use. Since most of their running occurs in December (with temp's usually below freezing) I use 180 deg thermostats and keep winterfronts covering the grilles so the engines (and hence the oil...) becomes thoroughly warmed each time they are run.
So far this strategy seems to be working. When drained the used oil still looks good (no entrained water droplets, no sign of emulsified condensation, etc).
I use only good quality 15W40 oil and Baldwin filters. Keep in mind also that modern oils and filters are far superior to what existed back when these tractors were designed.
I say go for the 2 year change interval!
