there is a lower bearing at the bottom of the steering shaft. remove the pipe plug on the bolster and check that. there is also a bearing on the bottom of the bolster steering shaft. if that one is out, you need to drop the shaft out the bottom and replace the bearing. carter and grunenwaldt has a whole rebuild kit for the blster for about 160 dollars, all the bearings, seals, and upper and lower bolster bushings.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
