Re: SMD oil resevoir
Posted by D Slater on December 17, 2008 at 15:14:40 from (72.65.151.177):
In Reply to: SMD oil resevoir posted by Kory Wieber on December 17, 2008 at 13:33:14:
You can mount a aftermarket or homemade reservoir somewhere on tractor. Also convert a belley pump to use as reservoir. If you don"t have one it takes one from a real late M or a SM tractor to clear the 12 inch clutch. Also a reservoir from a factory equiped live hydraulic system that goes under fuel tank could be used. If your tractor is below serial # 28181 the battery would need moved from under tank and control mounting for choke, pulley, switchover lever and starter switch would need modification to mount reservoir. If tractor is serial 28181 or higher you just need the late reservoir and all brackets, switchover and starter engaging lever pivot stud to mount.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
