Posted by glennster on December 18, 2008 at 07:37:00 from (76.222.57.166):
In Reply to: 240U manifold/exhaust posted by IH 240U on December 18, 2008 at 00:57:24:
im trying to remember on my 240u, i think the bolts go thru the u casting and into the manifold. you can try soaking in penetrating oil with some heat, tapping on the bolts, or an impact set on very low power just to scare the bolts a little before putting the torque to it, try tightening and loosening. or you may want to grind the heads off the bolts and lift the casting off, then work on the rest of the bolt that is sticking out of the manifold. that is a tough call. worst case senario is the bolts break off flush in the manifold and to will have to drill em and retap em.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
