Posted by Bob on December 18, 2008 at 08:47:37 from (69.178.228.68):
In Reply to: Re: HV magneto posted by Red Dave on December 18, 2008 at 08:32:53:
To add to that, the mag's impulse should trip @ TDC, and NO earlier unless you want a busted starter (which could be YOU, if you ever hand-crank it).
As the impulse trips, the rotor will jump ahead to a location near the high-tension terminal of the next cylinder in firing order.
At startup, when the engine is turning fast enough to kick out the impulse, the timing advances, all at once, to full running timing, as determined by the specific impulse components specified for that engine application. (Somewhere in the 25º to 30º BTDC range.)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
