Re: Soldering advice
Posted by Bob on December 18, 2008 at 08:51:41 from (69.178.228.68):
In Reply to: Soldering advice posted by DRC on December 18, 2008 at 08:45:40:
Get the parts good and CLEAN.
Use a good "tinning flux" and acid-core solder.
"Tin" the joint area on the tank and bracket ahead of time,
Easiest is to use a honk'in BIG old-fashioned "soldering copper", as there would be less chance of overheating the tank and causing a seam to leak.
When done, THOROUGHLY clean off the flux/acid reside with hot soapy water.
GOOD LUCK!
