Posted by Jim Becker on December 18, 2008 at 09:36:03 from (71.252.139.51):
In Reply to: Soldering advice posted by DRC on December 18, 2008 at 08:45:40:
I suggest that when you try it, you have the radiator filled with coolant up to the point where the core is completely filled and the liquid is just into the bottom of the upper tank. Do not have it high enough to cover the back side of where you need to solder the bracket to the tank.
The coolant will keep the areas that don't need repair from coming unsoldered. If the coolant is too high in the tank, you will not be able to get enough heat into the areas that you are repairing.
You can add more coolant before working on the overflow tube.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
