Re: T/A eliminator kit ?
Posted by Randy in NE on December 18, 2008 at 11:23:18 from (204.124.193.191):
In Reply to: T/A eliminator kit ? posted by Ole Shovel on December 18, 2008 at 09:22:51:
I guess that I will ask the question. Why? If the TA is properly adjusted and used properly it will last a long time. I know a guy that has a 1466 that he turns down to 250 hp for field work at tractor pulling. He has loaded duals along with over 4,000 lbs of weights and the cab. He figures that he is around 26,000 lbs. Even abusing it like this the TA has never moaned or groaned. If the operator isn't smart enough to properly pull the TA then with an eliminator kit in it he is probably going to tear the clutch out of it. I don't get to run my brother's 1066 very often but I do know proper use of the tractor and only drive it that way. I know that if I don't then I will be standing there watching them run it.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
