Re: 350 utility lp
Posted by NewYorkTom on December 18, 2008 at 15:44:06 from (24.190.86.163):
In Reply to: Re: 350 utility lp posted by Dellbertt on December 17, 2008 at 19:29:41:
Hi. I have just purchased a 300 U and want to pull the bottom cover plates off to replace the gaskets. The 2nd cover gave me about 1 quart of oil/grease. What can I expect when I pull the 3rd "T shaped" cover. I"m concerned that the 15 gallons of trans oil will come gushing out or can I expect the same as the end compartment. Thanks. Tom
