It has a common sump with the transmission. The filter is on the right side of the torque housing behind the hexagon cover with six bolts, opposite the hydraulic pumps on the left side. there is a check plug on the side of the rear end housing in front of the clutch pedal. You fill the unit with oil by taking off the plate on the top off the transmission on the right side opposite the gear shift, or the gear shift itself would work. While you have it off cut a hole in the plate, then weld a short inch and a half pipe 2 or 3 inches long to it and put a threaded cap on it for the next time
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
