Re: C Starter Switch
Posted by Gene Bender on December 19, 2008 at 04:33:33 from (67.55.226.75):
In Reply to: C Starter Switch posted by IndianaRed on December 18, 2008 at 18:20:00:
Your starter should have a tapered button on the rear and is operated by a pull rod if it is the correct starter. Over the yrs many starters have been changed some with a threaded stud. If the button is at the front it is for an A or a B and those operate with a pushrod. You also need a wire going to the ammeter.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
