Re: Model C with rpm problem
Posted by Randy in NE on December 19, 2008 at 06:41:26 from (204.124.193.191):
In Reply to: Re: Model C with rpm problem posted by Brooksie on December 19, 2008 at 06:24:04:
The engine rpm should drop when the lever is pulled back. The throttle plate has notches to hold the throttle in a given position. Several things could have happened. On one of mine the tooth on the throttle handle was worn down. We welded a small bead on the tooth and then I filed it down to a sharp point. Another thing could be that the grooves in the stationary part of the throttle plate have been round over through years of wear. It is also possible that the bolt holding the throttle lever is not tight enough. There is a spring in there and this may be allowing the throttle to drop back to the idle postion. O.E.M. Tractor parts has the entire throttle assembly for $68.00 or the throttle handle for $32.00. You could probably also get through your CASE/IH dealer.
