Posted by labman98 on December 19, 2008 at 10:21:26 from (65.216.74.168):
In Reply to: Re: stuck 560 d posted by minnesota red on December 18, 2008 at 18:24:34:
I have done this trick before as well. It does work! I tried it on a farmall H. I used a pipe wrench on the front starter shaft with a 110 pound weight. I also used a block of wood pushed by hydraulic jack to push a piston down. (A log chain went around the frame to hold the jack from moving.) Worked well. Was sitting oustide since '85 and it runs perfect now. Although we did put new rings in. I also found out on others that if you hit the piston down to hard it will break the sleeves at the top ridge. So be carful of that as you will have to remove the piston and sleeve together (push up from bottom) Good Luck!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
