Re: 1066 IH Westendorf WL40 loader
Posted by Lee in Iowa on December 20, 2008 at 08:09:11 from (66.172.198.68):
In Reply to: 1066 IH Westendorf WL40 loader posted by Jim E. A. on December 19, 2008 at 21:01:33:
I know you had to have a spacer if you had a factory cab on a 1066. I don't know if you do w/o a cab. My 856 with wl40 does not have spacer, but I don't know if they are exaactly the same as a 1066. If you do need check around with some dealers or traders for a used one, the new stuff is usually pretty high. Lee
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
