Re: Installing points in H4? Magneto
Posted by Gene Bender on December 20, 2008 at 15:39:59 from (67.55.226.75):
In Reply to: Installing points in H4? Magneto posted by Brad in WI on December 20, 2008 at 14:57:12:
You need to remove the mag from the tractor as the condensor is removed from the back side. There should be a cover where the condensor sllides out. There is also a screw holding the condensor. You will also need to remove the threaded piece where the kill sw goes. Remove that fitting first as the screw with the bracket holding the condensor will hold the cond to unthread the fitting. The three screws will jold the end so you can get to the points. Dont remove the outer cover as you will get the rotor out of time. Set the pts a 13thous. I would get someone to help that has done it before or you can end up with a mess. Just remember where the rotor was pointed when you remove the mag.
