Re: H4 mag
Posted by JFavor on December 21, 2008 at 08:50:17 from (205.188.116.73):
In Reply to: H4 mag posted by newtattoobob on December 21, 2008 at 08:10:28:
Don't know about using an ohm meter. It may be too sensitive. Never tried it. The obvious is; be sure nothing is touching that would ground it. I've use a test light several times. Light goes out when the points open. This works go for initial timing when you've had the distributor out.
