Re: Valve guide seals for H
Posted by RustyFarmall on December 21, 2008 at 09:45:17 from (209.152.78.9):
In Reply to: Valve guide seals for H posted by J Muehring on December 21, 2008 at 07:22:23:
A 1/2 quart or so of auto trans fluid (ATF) per 10 gallons of gas won't hurt a thing. You might even be able to use the full quart. Another possibility would be to use 2 stroke oil mix. I think the 2 stroke stuff might have a fuel stabilizer in it which would also be a plus if you don't use the tractor for extended periods.
