If you can put it in all gears, and when the clutch is let out, nothing happens, the clutch is probably out. Secondary possibilitys would include: ta clutch and ramp and roller are both out, Splines on clutch shaft are torn off, Clutch hub damper springs are toast. There are ways to see inside, but not fix anything. Also a major failure of the final drive (ring/pinion, or bull gears) will also give this symptom. Look into the trans to see motion through the fill hole. Good luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
