Re: Replacing cutout with regulator
Posted by Janicholson on December 21, 2008 at 16:07:02 from (64.83.205.193):
In Reply to: Replacing cutout with regulator posted by bustedbudget on December 21, 2008 at 15:54:40:
Three quick checks to make. The third brush in the gen may be set too far from the regular brush. Adjust it as close as possible. (can be done from outside) without removal.
The second is to be sure the new VR is grounded well. A third factor might be remaining connections to the light switch. Remove all these, only a single wire needs to be connected to the F terminal from the VR Field terminal. JimN
