Re: Farmall M won't run
Posted by Andy Motteberg on December 21, 2008 at 16:27:37 from (4.143.219.64):
In Reply to: Farmall M won't run posted by George in Nebr on December 21, 2008 at 16:10:29:
Make sure the float level in the carb is set correctly and the needle is not sticking. Make sure all the carb adjustments are correct. Make sure there are no air leaks where the carb mounts to the manifold. If it has a in-line fuel filter, get rid of the filter.
