Re: 1066 IH Westendorf WL40 loader
Posted by Doug-Iowa on December 21, 2008 at 16:35:10 from (208.126.3.6):
In Reply to: 1066 IH Westendorf WL40 loader posted by Jim E. A. on December 19, 2008 at 21:01:33:
I used a piece of 4"x6" rectangular tube 3/8 wall on my WL40 to clear the cab. Welded it to the loader frame and relocated the latch block to match the hook on the tractor frame. No issues thus far.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
