Are you getting any fire to the sparkplugs? Pull off one of the plug wires while someone makes an attempt to start the engine. If there's no fire you need to rub the points with some 320 wet or dry. If they're burnt replace them. Install a new condenser too. If this doesn't help you may have a weak coil. I would install a new set of plugs too. If you have a distributor you need to see if you're getting battery voltage to the coil. With the points open and with the ignition switch on you should have battery voltage on both small terminals. You need a fully charged battery and the alternator or generator working to keep the battery charged. That's required when you have a distributor. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
