JimN's advice below is right on. A couple more comments:
If everything is working right the ammeter should show about 15 amps of charge at full RPM immediately after startup. It should then taper to 3 - 5 amps at full RPM as the battery reaches full charge. And with the lights on it should show 3 - 5 amps at max RPM.
If you ground the generator field terminal then get ammeter readings as above, it says the problem is with the regulator....either a poor ground or the regulator itself is not working right.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
