Re: 300 utility problem
Posted by Dellbertt on December 22, 2008 at 05:37:24 from (209.172.21.243):
In Reply to: 300 utility problem posted by bigtomato on December 22, 2008 at 04:56:40:
Did you notice if the gen was operating while plowing.
Did the noise continue until you turned the key off.
Did the noise return at turning the key on.
Does gas run freely from the carb supply line.
Tap LIGHTLY on the carb housing then try starting.
Check ALL coil wires.
Check distributor wire.
Disconnet carb air intake hose and try starting.
Try small amount of starting fluid to see if it will fire.
Dell
