Re: electrical questions farmall H '47
Posted by Andy Motteberg on December 22, 2008 at 19:14:10 from (4.143.222.207):
In Reply to: electrical questions farmall H '47 posted by Doug M on December 22, 2008 at 15:53:09:
A four position light switch should have H L D B (Hi-Charge, Low-Charge, Dim-Lights, Bright-Lights) positions, a 3 should have O D B (Off - Dim - Bright). A generator looks similar to the body of the starter, has a pulley on it and a voltage reguator or cut-out mounted on top the generator. On a H, if yo had a alternator, the hood is most likely cut out so it can fit.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
