The fuel is not getting to the carb at a rate fast enough to run well. There is a screen at the carb fitting. Also remove the sediment bowl and put a pan under the opening. open the valve. It should come out in a pencil size stream. Let it do so for 30 seconds or so. If it trickles, the tank outlet on the sediment bowl fitting is plugged up. JimN
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
