Re: Super A governor update
Posted by Hugh MacKay on December 23, 2008 at 03:57:12 from (216.208.58.173):
In Reply to: Super A governor update posted by Ron Valentine on December 23, 2008 at 03:22:05:
Ron: The items you listed usually cure these. You don't need to add lubricant, the governors are lubricated by timing gears with crankcase oil. It's 20 years since I did governors on my SA and 130, still both working well, so I must be right. 20 years ago I had no one to ask, however when I took mine apart everything happened as you describe, even the bearing falling apart.
