We had ours turned WAY up for the chopper with no trouble. But we still only pulled the tillage equipment that it pulled set stock, and didn't weight it any heavier. It will last longer than a 2+2 cranking that hard. I beleive the 466 had a different cylinder head, swapping the head (and the injector lines) should increase your power through better airflow, and helps with the EGT if you go into the pump. Our 1066 was built to be a puller and when the Deere dealer put the last t/a in for us their dyno operator cut the dyno out at 170 hp, the governor hadn't kicked the fuel to it yet, and any dummy off the street would have known when that happened. We think that the previous owner decked the block and supposedly the turbo had 436 or 466 wheels in it. Fuel use with it was similar to the stock 10 we had.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
