Posted by Greg-N-CA on December 23, 2008 at 05:56:11 from (66.81.221.100):
In Reply to: Super A governor update posted by Ron Valentine on December 23, 2008 at 03:22:05:
Ron, good job! As Gene recommends, you will want to check your bearings and bushings for clearance, rust, etc. I had to replace the shaft and the weight pins too. Check the replaceable bumpers that are pushed/pressed into the housing too, they are wear points. Don't forget the bushing in the block! After I cleaned my housing in parts cleaner, I applied a new coat of glyptal to prevent the housing from rusting. Good to go for another 60 years!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
