Re: B414 Hydraulic lift
Posted by JimB2 on December 23, 2008 at 06:41:40 from (72.137.115.49):
In Reply to: B414 Hydraulic lift posted by Lynn Schaal on December 22, 2008 at 21:20:16:
Hi Lynn, there are two levers that operate the 3pt hitch. The one closest the fender is the draft control and should be fully forward except when using in ground implements like a plow or cultivator. The second lever is the up/down and is closest to seat. There are two valves at the front of the seat. The one at your left hand is push and turn a 1/2 turn and it controls the the GPM flow to 3pt hitch either 3 or 6 GPM. Pushed in or SLOW position is 3 GPM. The other valve at your right hand is a SHUT OFF valve that either lets hydraulic oil flow to 3pt or auxiliar vale and this valve should be in the OPEN position to allow 3pt to work. Check 3pt hydraulic oil lever by opening pipe plug behind the seat on top of rockshaft casting. Should be able to see hydraulic oil on top of a shelf when you look down the hole. Use IH Hytran or equivalent to top up.
There is also an inlet filter but that shouldn't stop 3pt all of a sudden. The other problem that occurs is front lip seal in hydraulic pump leaks hydraulic oil into crankcase. Check crankcase oil lever to see if is over full.
Hope this helps & happy holidays
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
