Re: Case 1816 skid loader
Posted by Brownie 450 on December 23, 2008 at 09:52:21 from (216.51.158.151):
In Reply to: Case 1816 skid loader posted by tjiniowa on December 22, 2008 at 20:20:26:
Should have mentioned to check for voltage at the wire going into the points. If no voltage there, could be a bad/ disconnected wire any where in the ignition circuit. Check by running a jumper wire from the hot terminal of the battery to the points hot terminal. If it runs with the jumper in place, track down where you are losing voltage in the ign. circuit.
