Re: Compression after replacing rings 1943 H
Posted by Janicholson on December 23, 2008 at 09:53:19 from (199.17.6.22):
In Reply to: Compression after replacing rings 1943 H posted by Jim Isler on December 23, 2008 at 09:25:38:
You can check it, but running first it will be more assured to be accurate. 120 to 140 depending on what pistons, and head combo. It could be higher if Gas head and high alt. pistons. Set the valves corectly, then check compression (no manifold is OK), all plugs out, full charge in battery. JimN
