Re: 706 lost its power steering
Posted by bc on December 23, 2008 at 10:16:37 from (68.88.175.43):
In Reply to: 706 lost its power steering posted by MIKE W (NY) on December 23, 2008 at 03:53:20:
Problem with changing the oil is that you also have a few gallons of fluid in the rockshaft housing up under the seat. You can pull the seat and cover to clean the oil and sludge out of that. Between that and all the fluid in the hoses and cylinders, it's almost impossible to clear the water out of the fluid. Then, unless you live in the desert, it will absorb more water over time through condensation.
At $150 a pop, more or less, for a fluid change, you will probably have to live with some what of a milky fluid.
I've had intermittant power steering too. Not sure of the problem although cold temps makes it worse.
It may help and you probably should run it with an extra 5 gal of hytran over the full line.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
