Re: Super H won't stay in 5th gear
Posted by Haas on December 23, 2008 at 13:16:47 from (12.65.30.37):
In Reply to: Super H won't stay in 5th gear posted by Bob Frazier on December 23, 2008 at 12:28:02:
I fixed a friend's Super H a few years back that had this problem. The problem with his was that the internal spline teeth on the 4th/5th sliding gear in the transmission were worn out. It was more than $200 just for the new gear. This wear happens because folks start out in 4th gear and then shift to 5th on the go, grinding the gears. Over time, and many shifts, this wears out the teeth on the 4th/5th sliding gear. It may be possible to replace this gear through the belt pulley housing opening after you pull the housing off. Not sure about that as I took the transmission top off on the one I did. Also, the clutch shaft has to come out and the input shaft/bearings/gear to the transmission has to come out the front of the transmission. That is done from under the tractor. In the case of my tractor, it ended up with a pretty complete overhaul of the transmission, including replacing all the bearings except for the rear bearing on the counter shaft. This was done because all the bearings had excessive play. The transmission lube system was all stopped up with sludge preventing proper flow of oil to the bearings. Another possible cause (I am told) for this problem is a worn out pilot bearing in the transmission. This is the bearing between the front and rear top shafts in the transmission. This I think can be replaced through the belt pulley housing hole without removing the top of the transmission, but all the stuff still has to come out of the front of the transmission. Short answer is fixing your problem is a fairly big job and will be expensive as well.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
