I assume you at talking about lining up the clutch plate so you can slide the drive shaft back into it when you rejoin the front and back parts of the tractor. I've done this several times on the A,C series tractors and I've always done it by eye ball and never had a problem. I recall though that the pilot bearing hole is even size, like 3/4 or 5/8 inch and a piece of steel rod the appropriate size will side in. The spline hole in the clutch plate is also even size, so if you have piece of rod and a bushing the appropriate size, then you have a clutch alignment tool that will work. Also if you can't find a bushing, just sticking the rod (or a cut off bolt in the pilot bearing will help you eyeball center the clutch plate as you install it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
