Janicholson said: (quoted from post at 22:13:52 12/23/08) We need more info as to alternator type. A 3 amp diode with 1000PIV rating will do well, As will a diode robbed out of a old alternator diode pack. The 4 terminals has us confused, as many four terminal alternators are external voltage regulator types from the 60s or early 70s. these are quite different, (they work but are more difficult to install. JimN
He probably means this 4 terminal diode & plans to use it in the excite terminal of a 10-SI, but he needs to confirm.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
