Re: diode for 12v conversion
Posted by tjiniowa on December 23, 2008 at 18:42:58 from (67.1.120.138):
In Reply to: diode for 12v conversion posted by mdaitc on December 23, 2008 at 17:50:40:
Should be easy to do, just take an ohmeter and test the terminals till you find the pair that goes one way and not the other (when you switch the black wire with the red) I have done this before, I just by the cheapest diode they have at Napa, for a Delcotron.
