i was referring to the diode that (as Old puts it) "diode that you use in the #1 terminal wire so you can stop the engine"
I just happened to have a diode laying around from something i picked up in a box from a sale a while back, and wondered if that would work - but i'd rather get the correct part.
Yes, JMOR - that is the diode that I have, and was trying to figure out if it would work in this particular application.
Thanks for the part numbers of the other diodes - i'll look at the specs on them!
Thanks!
This post was edited by mdaitc at 19:22:12 12/23/08 2 times.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
