Re: diode for 12v conversion
Posted by John T on December 23, 2008 at 19:27:15 from (66.244.97.31):
In Reply to: diode for 12v conversion posted by mdaitc on December 23, 2008 at 17:50:40:
If you using a diode to prevent ignition run on after the ignition is turned off as is done when wiring a GM 10 SI Alternator to excite the lil No 1 side terminal, I recommend instead a current limiting safety resistor anywhere from at least 10 ohms up to 100 ohms will work or else a small incandescent lamp which also serves as an "idiot light" to indicate charging..... About any diode will work provided its DC voltage withstand rating (PIV) is 100 volts or so and around 3 amps or so, although I like the higher amps and/or PIV simply cuz they may have bigger easier to wire leads....wire them - cathode end towards alternator...
John T
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
