Re: Super H won't stay in 5th gear
Posted by Dean O on December 23, 2008 at 21:09:38 from (76.30.75.21):
In Reply to: Super H won't stay in 5th gear posted by Bob Frazier on December 23, 2008 at 12:28:02:
Same problem with my 46H Pulled the top plate off after welding up the shaft didn"t work. Gears are in good shape but the bearing that held that assembly was worn and allowed the assembly to drop down on the back end. 5th gear fork was also bent. Replaced just the bearing and re-adjusted the fork and it works fine now.
