Re: 706 DOSN'T LIKE TO SHIFT IN REVERSE
Posted by minnesota red on December 24, 2008 at 05:07:34 from (65.73.95.207):
In Reply to: Re: 706 DOSN'T LIKE TO SHIFT IN REVERSE posted by MIKE W (NY) on December 24, 2008 at 04:47:50:
Then I would bet that you problem is with inner linkage.
pull the cover off the center section below the steering wheel by the park brake and their will be a rod that runs down in there.
You want to find the one that moves when you shift the range lever,use a magic marker to mark a line up and down on it and have someone shift it while you watch.
If the line stays lined up then it is inside the rear.
Takes more time than money to fix.
