Re: c123 governor
Posted by Hugh MacKay on December 25, 2008 at 02:49:12 from (216.208.58.116):
In Reply to: c123 governor posted by RDJ Farms on December 24, 2008 at 18:00:25:
RDJ: Not near as complicated as you think. Turn engine to TDC on compression number one plug, then slide the gear back in with rotor pointing at 2PM standing behind it. You may have to remove distributor, however that is not complicated. Main thing here is rotor at 2PM when Number 1 is at TDC compression. Not hard to find compression, stick finger in no. 1 plug hole and turn hand crank.
