Re: Super H won't stay in 5th gear
Posted by matthies on December 25, 2008 at 06:32:33 from (12.10.27.178):
In Reply to: Super H won't stay in 5th gear posted by Bob Frazier on December 23, 2008 at 12:28:02:
Neighbor had me replace the 4-5 gears also, never drove the tractor myself. Before we put the top cover on I checked the detents. Sure enough the spring was broke for 5th. Check yours while apart. chris
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
