Posted by Janicholson on December 25, 2008 at 10:12:06 from (66.173.50.128):
In Reply to: no spark at points posted by Richard Hayes on December 25, 2008 at 09:07:47:
I think Glenster is on to it. The bolt and nuts that go through the side of the distributor are stacked in this order (rememberance here) With the bolt out of the hole, a insulator with a snout goes into the hole from the inside, centering the stud. The stud is next, with a thin flat washer under a nut, from the inside out. A flat insulator goes on the outside of the housing. A thin flat washer goes on the outside next, then a nut. A little but more of the stud is inside than out, but not much. Outside next is a flat washer, then the ring of the connection wire terminal end, then a flat washer, lock washer, and last nut. On the inside (from the nut mentioned above)is a flat washer, then the spring from the points (some with a copper strip, some not) then the lead from the condenser, then a flat washer, then a lock washer, then the inside last nut. If this stud is touching, or allowing any part of the metal called out above to touch the dist. housing it will not work. (the coil negative should be connected to the ignition sw, the positive is connected to the distributor. It will work the way it is but the spark will be compromised. let us know what happens! Seasons greetings. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
