Re: Marry Christmas
Posted by Janicholson on December 25, 2008 at 10:14:47 from (66.173.50.128):
In Reply to: Marry Christmas posted by The tractor vet on December 25, 2008 at 07:43:33:
The only fixen I do today will be the advice I give to others. I also thank you for your wisdom and direct approach to wrenching. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
