Re: Stuck Farmall BN's
Posted by Andy Motteberg on December 25, 2008 at 14:16:16 from (4.143.222.217):
In Reply to: Stuck Farmall BN's posted by Clarkbug on December 25, 2008 at 11:43:51:
If the cylinders had water or antifreeze in them, you need to pull the head off and check out the cylinders. Clean the rust from the cylinders. If they look okay, put PB Blaster in the cylinders, great stuff, I've freed up many engine with PB Blaster. While it is soaking, tap the starter every once in a while. I think if it had water in the cylinders, you need to rebuild the engines.
