Re: My W6 won't run
Posted by LMack on December 25, 2008 at 17:22:16 from (66.156.32.45):
In Reply to: My W6 won't run posted by trutherf on December 25, 2008 at 16:55:42:
Yor are going to have to tell us if the motor is locked up. Can you spin the engine with the starter? If not you probably have a crank shaft or rod issue. You say it seized up. If it was running and it seized up I would get inside the crank case and see what happened before any more damage is done. Look for holes in the side of the crank case. larry m
