Re: Just bought an H and I see I have antifreeze in the oil
Posted by LMack on December 25, 2008 at 17:44:24 from (66.156.32.45):
In Reply to: Just bought an H and I see I have antifreeze in the oil posted by dave westlund on December 25, 2008 at 17:24:08:
Farmall engines are sleeved. It could be a gasket seal at the head. It could be a poor seal between a sleeve and the block. It could be a crack caused by a past freezing. Don't want to sound negative but you might want to consider a complete tear down with all new gaskets. Take a good look at the sleeves and pistons and look for internal cracks. You can purchase a sleeve and piston kit on this site. larry m
